Whats the difference between the 98-00 & 01-02 LS1's?
i'm sure i'll be corrected if i'm wrong but... here's the diffs that i know:
98 had 26# injectors
99-00 had 24# injectors
01+ had 26# injectors and the ls6 intake and no EGR
and i believe the 02's got a little bit different cam, something about the base circle being smaller??
Deogey
Captain obvious
98 Camaro SS
http://www.rednecktoyz.com
Deogey
Captain obvious
98 Camaro SS
i do believe that they did change the cam i have heard that they went to a cam that was designed for the chevy trucks so that the ls1 would make more torque on the low end.
98 Z28, Onyx Black, A4, t-tops, other than the free mods, a random tech cat back, and a whisper lid, it is stock
You're right on the injector changes, just the wrong sizes. '98's had 28# injectors, 99-00 had 26#, and the '01-'02's have 28.5# injectors. They also started using the truck cam in the '01+ cars, as well as the LS6 intake and no EGR. The exhaust manifolds changed in '00, so that's why you see headers listed as 98-99 and 00-02. I've also been told that the head casting procedure changed for the '01+ cars, but I've yet to have that verified.
Trevor - LGM
'02 SS: 11.63 @ 114.06 MPH, 1.588 60'; 3,515# raceweight, 1,102' D.A.
naturally-aspirated with bolt-ons, a cam, and a fat converter!
L.G. Motorsports (972) 272-7753
Check out the SS!
Trevor - LGM
Check out the SS!
Gear ratios in 98-99 are higher as well unless you took the 3:23 option in the Z. the SS have 3:42. The other Z's have 2:73
airplane gears, but good on the highway!
You can check yourself if you don't already know: Codes = GU2 = 2:73
GU5 = 3:23
on Z28's.
1998 Z28. Artic White.
GU5 = 3:23
on Z28's.
- SS hood
- Sport Appearance pkg.
- Ported, Polished MAFH
- Free ram air Mod.
- Flowmaster Exhaust
- Custom Stainless tips
- T-tops
- SLP Lid
- KN air filter
<font face="Verdana, Arial" size="2">Originally posted by Jay-mak:
GU5 = 3:23
on Z28's.
</font>
GU5 = 3:23
on Z28's.
</font>
The '02 came standard with Z rated tires and I also believe the power steering cooler is standard on the '02 - but I'm not sure.
'01 Mystic Teal Z28
A4/3.73
Mods List Here
12.12/112.81/1.70 60'
325 rwhp/341 rwtq
www.MysticZ28.com
NorCal LS1/LT1
"To play it safe is not to play"
not really related to parts you buy, but there was a discussion on ls1.com how in 2001 and 2002 I believe the automatics, had a low torque start option where if you put the shifter at "2" it would start in 2nd gear for low traction surfaces like snow or rain. In the prior years if you had it in "2" in the auto it would still start in 1st gear, but not shift past 2nd.
I see some of you guys are posting about the different gears. I have the 2.73 ones....not the performance option. Is there really a huge difference between the two....do the 2.73's really dog the car in any way?
Red 2002 Z28 A4
Leather, T-Tops
All Stock.
Mods soon - Lid, Exhaust
Red 2002 Z28 A4
Leather, T-Tops
All Stock.
Don't the 01-02's also have an LS6 clutch?
Chris Anderson
Black 99SS M6 all SLP Options
Mods - Cutout, Direct-Flo Lid, GMS MAF, Hurst Shifter with Chrome Handle, Bridgestone Potenza RE730 Tires.
Best ET 13.60 @ 104.31
Best MPH 13.92 @ 108.81
Chris Anderson
i dont know if they come stock with the z06 clutch but i do know that they had probs with the z28 clutches and when you went to the dealership to have it replaced they put the z06 clutch in.
carguyshu
01-22-2017 11:19 AM
10-31-2016 11:09 AM
Sergio
01-27-2016 04:27 PM
Aneurysm
12
09-10-2002 05:21 PM
