whats to gain from a hypertech programmer
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
would i gain anything from that on my ws6? what im really looking for is like what i had in my formula extra degrees of timing, speed governor delete (do i even have one?), etc...
where should i go for that?
also... oil change light was on for a couple hundred miles.... i just changed the oil yesterday... light is still on whaddo i do?
thanks
Jared
thanks
Jared
Re: whats to gain from a hypertech programmer
oil light:
turn the ignition on, oil light should come on...hold down the trip odometer button till the oil light flashes...that should reset it. i think...something like that
the hypertech is useless really. the programming is not proven to help much. many have had a lose of pwer from them.
they are only good for adjusting shift points, firmness, redline and tire/gear changes
No WS6 that I know of came with tires that were not rated for at least 145+, nor do they have any governor. As for the Hypersh!t programmer, its good for the basic stuff like someone already said, shift points, tire size, crap like that. If you want real tuning go for www.pcmforless.com.
oki doki... no hypertech. gotcha.
oil change light still on... the trip button pressing thingy didn't do it...
Originally Posted by L8ER
I had to hold mine in for about 15 sec for it to work, but that is how you reset it. Dont start the car just have the key to on and then hold the reset button.
as far as the governor, stock from what ive seen with my car is past the 155mph mark, some on here say 163mph, 160 + momentum. how they tell 163? i dunno. i do know i had mine past 155 5-10 seconds later it shut down til i got back to about 125-130. (open highway, noone but a friend trailing me around) no animals killed in that act(s) of stupidity.
Originally Posted by pHEnomIC
Dont get rid of the speed governor if you dont have z rated tires or they blow the ^$$# up.
guess i was living on the edge when i was doing 145 on the t-rated tires i had. T= 118 mph. tires just don't explode because you are going faster than their rating. the speed rating is the limit they can do safely and still dissipate the heat generated for extended length of time. yes, going above the speed rating isn't a good thing. but the tire can handle it for a limited amount of time. the faster you go, the more heat build is in the tire. due to it's inability to dissipate the heat fast enough.
