Who has a K&N Ls1 setup?
...um...
as far as i know, just stop by a local auto parts store, find the right k&N filter for an 1998-up camaro...pop the hood, unlatch the two clips you see right in front of you, remove the filter and place the k&n in its place the way you saw it in there.....
...hope that helps...
Thanks for the reply, but maybe I was looking for the wrong thing. After doing more research I learned that I really want to replace the MAF housing with a whisper lid. http://www.installuniversity.com helped out a lot with showing how the removal of the MAFH and install of the whisper lid. From the moment I saw the silencer on the stock MAFH I knew that was restricting air flow.
detroitmuscle
07-31-2015 04:21 AM
