Will 1999 Z28 Camaro Gauge cluster work on a 1998 Z28 Camaro?
Will 1999 Z28 Camaro Gauge cluster work on a 1998 Z28 Camaro? I know 1998 V8's differ from the 1999's and up but I dont know if the same goes with the gauge cluster. Are there also some differences between the interior wiring of the 98's and the 99's? Thanks!
Re: Will 1999 Z28 Camaro Gauge cluster work on a 1998 Z28 Camaro?
i know the tach wire is different, other than that
Temp gauge in the 98's reads the actual motor temp.. the 99-02 cars are programmed to sit at 210... more like an idiot light than a gauge... this should be a source of problem if any of the electronics controlling the gauges are in the gauge pod themselves.
Gm ditched the actual temp b/c the alum motors heat/cool faster and people were bringin in their cars complaining about abnormal temp fluctuations... or so the rumor goes..
hotrodyou1
12-20-2014 10:05 PM
ChrisFrez
12-07-2014 06:01 PM
