Will I flood it?
Will I flood it?
I had a buddy of mine tell me that I might possibly flood my engine after im done with my build. I installed 42lb injectors. I hope to make a lot of power and I know that with a tune, you can tune them down.... I went with the larger injectors because I hope to one day supercharge or turbo the car....Anyways. Will I be in trouble if I run the car after my build? Will the stock tune not even allow the injectors to spray as much? ?
The PCM will not know the injector size difference, and will keep them open as long as the stock injectors should be. That means you'll be seeing a LOT more fuel, and the engine will run very poorly, if it all, without a tune. DO NOT put the injectors in until you're at the shop just before the tune.
What makes you think that you need to ''run the cam a little bit''? It's not an old school flat tappet cam.
Do whatever engine work you plan on doing. Reassemble with the stock injectors. Drive it to get tuned and explain to the tuner that you will replace the injectors in the parking lot or in the back of the shop. Swapping the injectors on the car should take no more than 10-15 minutes. Or you could pay the tuner to do it, but that would be a waste of money.
well....
I called the Tuner today. I will need to get the car towed there, due to selling the stock injectors, im left with the 42s. He will do a base tune. I want to break the new **** in for a week, drain the oil and take it for its real tune. He said he'll do the base for $100 and deduct some from the regular tune which is 335 without the deduction... He was saying something about a oil catch can? Why?
If I were you I would ask the tuner if he has a stock set of injectors laying around that you could borrow to drive the car in. ANY tuner worth ANYTHING should have a few sets collecting dust...
meissen
08-11-2015 06:05 AM
jasonduaine
03-07-2015 09:44 AM
