Yank Sportsman Transmission
My tranny has started to slip and shift strange when I go from partial throttle to a stronger partial throttle. It shifts fine if I use WOT. Has anyone had any experience with the Yank Sportsman Transmissions?
A couple guys down here put them in and both had problem's
That's why I'm looking into either a new one from GM or the place in Las Vegas (F-body transmissions), but they haven't returned my e-mails?
This is just what I've been told, you can try them if you want.
Thanks for the info.
I am also looking into trannies from the following places:
http://www.fbodytrans.com/
http://www.rosslertrans.com/index.htm
http://www.transmissioncenter.net
I've called all those places, but for shipping Fbodytrans is the cheepest for me.
I'm going Vegas on the 24th and plan to swing by to check them out.
Another place guys on the LS1tech board said to try was LS1 Speed Inc.
If you get one let me know how it goes, if not I'll be back on the 29th and let you know how it went!!!!
I ordered a stage 2 from this place:
It should be here Tuesday, I wen tup and talked to the guys (good guys).
I'll let you guys know, But still have to get a new convter
How do you like you Yank 3200, my 3000 is going to be sent back, looked at and restalled to 3200.
Andrew
Andrew
