***header install*** - wont start!...any ideas?
#17
Re: ***header install*** - wont start!...any ideas?
Originally Posted by CreatiVe2
hey slow... you in philly? what part?
I live about 5 minutes from the Philly airport, near where 95 and 476 intersect..
#18
YOU HAVE TO HAVE YOUR MAF INSTALLED! Otherwise your pcu wont recognize that you have air coming in and wont add the fuel to match. I would also make sure you have your front two O2 sensors in as well. If you took our your EGR, make sure the holes are blocked as well to keep vacuum and you should be set.
#23
Yeah but even with them too tight they don't bend on their own. They will just hang the vavle open, the problems then comes from them keeping them open a little when the piston is coming up at them and the collision causes the bend pushrod... Some time you get lucky and it doesn't hurt the valve or the piston, but I have sen 2 vehicles personally that one bent the valve also and in my case the head of the vavle broke off and dropped into the cylinder... Trust me you don't want either to happen..
#25
Originally Posted by DiabloGT
do u really need 02 sensors in a 95 obd1 if u dont go to emissions? does it even do anything?
#26
car is runnnning striaght LT's =) so loud! just threw some new push rods in. im running no o2's i got a 96 tho. **** is crazzzzzzzzzzzy i love it! <333333
10-31-2016 11:09 AM
armedtrigger
02-24-2015 08:30 PM
