[O2 probs] What happens if I unplug the O2 sensor?
Ok, I've had a problem with the O2 lately. (on the right side) so I ordered a new set and put them in. The wires that go to the right side O2 got burnt on my headers about 2 years ago (redid the wiring) and I think that one of the wires has a loose connection now and needs to be redone again. (its throwing the code saying 'O2 rich' and, of course, dumping fuel to the cylinders like crazy) Its very intermittent . It'll run fine one second then run really bad...the 'SES' light will come on and it'll run fine...go off...run fine...then run like crap, throw the 'SES' light...over and over again. Is there anything else that could be causing this problem other than the bad/loose wire? That's where I'm going to look first as I'm 99% sure that'll fix the problem...but is there anything else (other than a bad PCM) that could cause this code? Also, I was just curious as to what would happen if I disconnected that O2?
Thanks in advance
Thanks in advance
ive been fighting the same EXACT problem you describe. which set of wires burned? do you have any pics? im pretty sure mine burned on the passenger side. my o2s have been disconnected for about a year now. no problems, and like 270miles to a tank.
question
hey NONO5.0
Does your car throw black smoke out the back when you step on it ???/I ask this because mine runs like you describe......you know, crappy, then good, then a SES light then good , crappy etc. sometimes awful idle..........And I got a hunch it could be the O2's.
THANKS IN ADVANCE FOR THE iNFO
Re: question
Originally posted by SATANAZ666
hey NONO5.0
hey NONO5.0
HEY, nONO5.0...DID THE O2's fix it for you????
Hope this helps!
14
08-11-2015 12:03 PM
whitehooptie
08-10-2015 07:02 AM
08-07-2015 01:26 PM
zajones
07-30-2015 02:18 PM
