02 firehawk exhaust on 94?
hey guys, a friend of mine just took off his SLP ypipe, and from that back with the 3inch exhaust. he gave it all to me. i was wondering if i will have any trouble having an exhaust shop install the catback and y pipe. it has only been on his 02 firehawk for 2000 miles. he just upgraded to loudmouth. thanks
The hanger locations are the same from the muffler back. The LR hanger design is slightly different, but will work with minor modifications. The intermediate pipes are different lengths between the two, so you'll need an adaptor. It's pretty easy to make it work.
the Y pipe won't work i think and it is probably just the same size tube as the LT1 pipe. The catback should work but i believe you will need a S pipe made if you have a 96-97 the catback should bolt up and work
carguyshu
01-22-2017 11:19 AM
