02 sensor problem, help!!!
i got a problem, my car was running like crap, it felt like it was running on 6 cylinders, so i had a diagnostic test done, and it was a 02 sensor, so i was wondering if i could replace the factory sensors with simulators, to save me a a lot of money.thanks...
Re: 02 sensor problem, help!!!
i dont understand, my car is a 96'ss lt1, it has 02 sensors after the cats, i was wondering if i could just plug in the simultors to cure my car from running like crap, instead of having gm replace the 02 sensors with factory units.
Or you could just shell out a few more $$ and do the job right the first time around. I mean, hell, I look forward to **** breaking on my LT1, afterall, I gota all the room in the world to work with I'd do it right the first time, get factory/OEM replacements so you don't have to work in the realm of no room any sooner than you'd like.
~Jon
~Jon
so do you think that the simulators would fix it if it were accually the rear 2 sensors that were bad???
yea, sorry about that, im getting to it, and i really dont want to spend alot of money that i dont have so i was wondering if it could be a quick fix for like 50 bucks, not 300, just a thought...
btw its a stock 1996 camaro ss m6
You can alway put sims in for the rear sensors and then you would not have to worry about them. Of course, that won't help with driveability problems from the front O2 sensors.
In your first post, you did not give much info to go on. No year of car or indication of what particular DTC was given (there are about a dozen or more O2 codes for OBD-II cars). It makes it hard to give an informed response.
yea sorry about that, but thanks again for clearing up some info, i guess all i can do is buy the sims, or would it be possible if i buy a new y-pipe, that would elimnate the cats, would i still have to retain the front 02 sensors???
