1/4 difference from 2400 to a 3600 stall?
Depends on what type and brand of converter....I had a 2400-2800 LPE converter which came with the 383 package...unk who actually made it for LPE....Stepped up to a Vigilante 9.5" 3600 lockup and got 5 solid tenths...dont know what your set up is, but that was with 3.42s...no other changes made...by the way the Vig has been in car for 7 years with no complaints...
--Alan
--Alan
the one i have now is the stupid slp 2400 stall. i should have went bigger in the first place but since my tranny is going it would have taken it out with it. so ill just put it in my new tranny that is waiting to be installed
going from a "cheap" 2400 stall to a PI 3600 will be very noticeable.
do you have plans on a cam or headwork?
for a stock setup a 2800 stall is optimum.
why do want a 3600? why not a 3200?
jesse
jesse
jesse
jesse
i want a 3600 with a 2.0 str to work with my 3:73s to get a little softer launch but still be able to pull pretty hard at the top. the reason i want a 3600 is to get closer to my max torque range.
so im hoping to gain around 4-5 tenths from the slp to the vig convertor.
carguyshu
01-22-2017 11:19 AM
