1/4 mile times & HP
Old 03-20-2008, 10:15 AM
  #16
bigbirdta94's Avatar
I Have A 94 Ta That Went 12.97 At 111mph With 303hp And 330 Tq. I Was Very Suprised With My Times
bigbirdta94 is offline
Old 03-20-2008, 10:18 AM
  #17
Jazsun's Avatar
Originally Posted by SS MPSTR
275rwhp, 13.8ish et's.
Theres no way hes gona run an 13.8 w/ longtubes, I could almost hit that w/ just a catback,cutout, and CAI. I'd say 13.4 if you drive it like a bat out of hell. Just dont be afraid to beat the ****out of it, and you'll be just fine .
Jazsun is offline
Old 03-20-2008, 11:42 AM
  #18
3DFORMULA's Avatar
Originally Posted by reamo04
you dont need more power, you need SUSPENSION AND TIRES
instead of the pulleys and roller rockers, get an adjustable torque arm, lower control arms, relocation brackets, and drag radials....
I agree here. It's about making it work.
I'd bet with the LT'S, you are making more power than me. But with NO traction you can't run the # I do. I still have manifolds on. I'd suggest 15" lite wheels and slicks for the track. Torque arm and LCA relocation brackets.
3DFORMULA is offline
Old 03-20-2008, 12:24 PM
  #19
'94 Bad A Z28's Avatar
I know it's auto vs. manual but when my car only had 264rwhp and 297rwtq it ran consistant 13.2xx's @ 104.xx so I see no problem with this car being able to break in to the 12's with a decent to good driver.
'94 Bad A Z28 is offline
Old 03-27-2008, 12:27 AM
  #20
ZPower_123's Avatar
Would subframe connectors and bigger sway bars help with traction ?
ZPower_123 is offline
Old 03-27-2008, 01:27 AM
  #21
LT1BanditTA95's Avatar
Atleast at what I have seen here in KS at my local strip this would be a more likly goal.
LT1BanditTA95 is offline
Old 03-27-2008, 01:29 AM
  #22
What did you have done when you ran your 13.2s at 264/297?
Old 03-27-2008, 01:32 AM
  #23
Not tryin to steal thread here.. But how do you like your BFG drs? Do they see street rarley? Im ethier goin with them or Nittos cus they last longer than the mts...even tho the mts will out hook them. The nittos I don't like because they are so much narrower than others..
Old 03-27-2008, 02:04 AM
  #24
Yank 2800 stall converter
Motive Performance 3.73's
T/A Girdle w/stud kit
SLP CAI
SLP "flow booster" aka air foil
Stock tune hyperteched for the gears.
Old 03-27-2008, 08:53 AM
  #25
SS MPSTR's Avatar
Since when does any mod guarantee an ET?
SS MPSTR is offline
Old 03-27-2008, 11:46 AM
  #26
Z97LT1's Avatar
When mine was a bolt on car, it had similar mods to this. It laid down 290rwhp, 325-ish rwtq, and ran a best of 13.2 at 107 on street tires.
Z97LT1 is offline
Old 03-27-2008, 01:24 PM
  #27
Ironxcross's Avatar
It doesn't. I ran only a .1 better when I got my longtubes. Why? Because I suck at launching.
On second thought the two loose spark plugs probably didn't help much with my time either...
Ironxcross is offline
Old 03-27-2008, 01:34 PM
  #28
PWR-TRIP's Avatar
I don't even know how much power i'm pushing out. I'm assuming 280-290rwhp.
PWR-TRIP is offline
Old 03-27-2008, 01:57 PM
  #29
Moderator
97ChameleonTA's Avatar
My mods and times are in my sig. The dyno results were SAE 314.9RWHP and 341.3RWTQ. The only weight reduction on my car is the spare and jack. I would hope that with 300RWHP he could run better than 13.2-13.4...
97ChameleonTA is offline
Old 03-27-2008, 03:26 PM
  #30
CANTONRACER's Avatar
Track times depend on a number of factors...
Location, which means track elevation, is it level, track prep.
Weather, which means density altitude.
Driver, which means the obvious.
Car, which means how is the car mechanically.
Start factoring all this in and guessing becomes moot.
CANTONRACER is offline
Quick Reply: 1/4 mile times & HP
