1.46" springs on stock heads, locators?
Alright, Im sure its been asked before but I couldnt find it. Im looking to put 1.46" springs on a set of lt1 heads... obviously the stock locators wont work. What are my options? I heard use just shims, but they wont really locate the spring on the head. Any help definitely appreciated!
Re: 1.46" springs on stock heads, locators?
Anyone? Ive basically got the parts, but wont commit to them until I know I can use them. They are k800's with 7* locks and titanium retainers.
Originally Posted by BUBBA
I guess I don't know what "locators" are---I do believe, however, that stock seats will accommodate 1.46 OD springs.JMHO
So just use shimstock eh? I was going to do the installed height properly, just didnt know if shims alone would keep the spring from walking around.
You need to use a spring locator to keep the spring from walking all over the place. You need the OD of the guide boss, and the ID of the spring, then call comp and order off this chart...
http://www.compcams.com/technical/Ca...106-07/312.pdf
I believe the guide is .557", you will have to measure your spring ID.
You don't need the locators in order to keep the springs from moving. I have ran a few sets of springs w/out locators, just shims - as have a couple of my buddies, with zero problems. Certainly doesn't hurt to run locators though.
Simply put - You are wrong.
