1.6 pro magnum rockers
Old 06-19-2008, 05:55 PM
95TALT1's Avatar
Car:95 trans am LT1
Valvetrain components: comp cam 224/236 .605/.622 on a 114, comp oem replacement lifters, comp push rods, comp pro mag 1.6 RR,
Anybody have any noise problem with the comp pro mag RR or the comp cam oem replacement lifters? I have a complete comp cam valve train and there is some noise that i cant seem to adjust out. I have adjusted the valves every which way.
95TALT1 is offline
Old 06-19-2008, 06:19 PM
I don't know what you are expecting, but it will never be as quiet as stock.
shoebox is offline
Old 06-19-2008, 07:24 PM
95TALT1's Avatar
how much noise am I to expect???
95TALT1 is offline
Old 06-19-2008, 07:41 PM
aboatguy's Avatar
A sound like a smooth running sewing machine
aboatguy is offline
Old 06-19-2008, 08:10 PM
Don 97 SS's Avatar
I don't think my valve train with Pro Mags NSA makes any more noise than my former 350 with a top end kit with Crower ss SA 1.6 RRs.
For me the main concern with a chatty valve train is knock retard; and i have none.
Don 97 SS is offline
Old 06-19-2008, 08:55 PM
95Blackhawk's Avatar
no more significant noise than I would have expected on mine.
95Blackhawk is offline
Old 06-19-2008, 09:35 PM
How much do you have?
shoebox is offline
Old 06-20-2008, 08:03 AM
97pontta's Avatar
Are the rockers self-aligning or are you using guide plates? I don't have the comps but I do have self-aligning 1.6 crane rockers and they are not as quiet as stock. I tried adjusting them many times only to get the same result. They sound like what was described above, "smooth running sewing machine". I installed mine over 5 years ago and they still sound the same. Just be sure you are using a LT4 KM.
97pontta is offline
Old 06-20-2008, 08:18 AM
ZL1modified's Avatar
Car:95 trans am LT1
Are you still running stock springs with that setup? how do adjust valves???
ZL1modified is offline
Old 06-20-2008, 09:24 AM
Kevin Blown 95 TA's Avatar
I had a problem with the Comp replacement roller lifters - the hard facing wore off the rollers. It didnt hurt the little Comp blower cam I had in there at the time, and it wasn't noisy. Comp, of course, didn't respond to any e-mails I sent with pictures asking about it. I had Crane rockers at the time. Now I got Comp Pro-Mag rockers and Crane replacement lifters with a bigger cam and still no noise.
Kevin Blown 95 TA is offline
Old 06-20-2008, 10:51 AM
95TALT1's Avatar
Well the noise is not like a loose rocker I know that. I have adjusted the rockers every which way. Even running. It doesnt sound as bad when you back off the rocker when running but still very noisy. It seemed like before that when it was cool it wasnt as loud but after a mile or two of driving and warming up it seemed to get louder. The spring kit is one from Navarez Racing which is formerly Combination Motorsports. The engine is brand new and has less than 150 miles on it. I dont think the engine has even seen 4k rpm yet. I noticed it shortly after first driving it. At first it sounded like an exhaust gasket. It got worse. Im thinking of trying to put some of my old stamped rockers on it and see if it is the rockers. If not then I guess it would be the lifters. Im so frustrated. I appreciate all the response. I just still feel something is not correct. What are your opinions on how far to turn past 0 lash.
95TALT1 is offline
Old 06-20-2008, 10:59 AM
95TALT1's Avatar
They are self aligning. I have adjusted them 1/8, 1/4, 1/2, and 3/4 past 0 lash. I even read somewhere on here you can go as much as a full turn past 0 lash. I havent gone that far yet. I may try that before I swap to stamped stock 1.5. I just dont want it to be that noisy. I would rather hear the injectors over the valve train. I definitely dont want to hear it with the hood shut.
95TALT1 is offline
Old 06-20-2008, 11:19 AM
Stl94LT1's Avatar
I have ran Comp Pro Magnum S/A and non S/A 1.6 rockers with my 224/230 605/622 cam. The non S/A rockers are a little quieter, but still make make some noise.
Stl94LT1 is offline
Old 06-20-2008, 11:37 AM
brubaker's Avatar
Your problem sounds much like mine was,you will need an automotive stethascope, get the car fully up to operating temp, pull the valve covers one at a time and with it running touch each stud and listen for any that are louder, if you find any pull that rocker and check for worn valve guides by moving the retainer side to side, if you do have guide worn pull the heads and have bronze liners installed. then you will need to correct you valve train geometry, if you are using nsa rockers "you should be with that much lift" make sure your rocker tips are centered, most sbc guide plates aren't right due to lt1 valve spacing, ajustable guide plates would fix that or try gmpp or trick flow. my comp 4808 guide plate were not right. then you will need an ajustable push rod to get the length right. but not all problems are the same good luck!
brubaker is offline
Old 06-20-2008, 02:40 PM
95TALT1's Avatar
Is it ok to go 1 full turn past 0 lash??? It seems to have quite down a lot. There is a little noise but not excessive noise. Of course I only drove it around the block. I plan on putting some more miles on it this afternoon.
THanks,
95TALT1 is offline
Quick Reply: 1.6 pro magnum rockers
