1.6 R.R. Suggestions
#16
Originally posted by ProjectTranzAm
Why did you pull out the intake manifold? Reason I ask is because I just got done resealing mine. I don't want to take it off unless I have to!
#18
Why did you pull out the intake manifold? Reason I ask is because I just got done resealing mine. I don't want to take it off unless I have to! BTW, are those full length's?
You do not have to pull the intake. If you want to make sure each cyl is at the top just get a piece of coathanger and stick it in the hole and you can fell the piston.
sleeperZ96BT
09-09-2015 08:28 AM
