1.6 RR search
1.6 RR search
The shop that is working on my engine thinks that my rockers are the cause of a ticking noise and i want to jump to the 1.6 ratio so Im looking for a set of 1.6 narrow body SA, roller rockers. what companies make narrow body SA? i can usually find the ones that are self aligning but i cant find any that specify that there narrow body. I dont know if im just not searching the right places or what but if someone could point me in the right direction that'd be much apreciated.
Re: 1.6 RR search
Roller rockers will give you a ticking sound aswell, that's the reason the Lt4s got a different knock module along with composite valve covers.
Comp. Cams
Scorpion
Crane
And a few others have the rockers you are looking for. If you do go to a NSA rocker, use 7/16 arp studs, 7/16 1.6 rockers, New valvesprings and Hardened pushrods. Then get a mail order Tune, i used www.madtuner.com You will be a happy camper.
Comp. Cams
Scorpion
Crane
Re: 1.6 RR search
well yea i know what they should sound like but its a tick thats louder/higher pitched then what it should be, not like the sowwing machine noise they usually make. anyways i know those brands make rockers i just cant find the narrow body one's or can you just specify that upon order?
autoxr166
09-25-2015 04:21 PM
09-11-2015 09:44 AM
