1.65's???? Roller ROckers???
Does anyone on here have any experience using 1.65 roller rockers? Are they just as safe as 1.6's with larger cams?
??? just never seen anyone on here talk about them...
I'm set on the 1.6 Pro-MAgs... but 1.65's sound like they can be fun...
Re: 1.65's???? Roller ROckers???
yeah you'd be getting a pretty good amount more lift, 30% i think if i calculate correctly.
but realize you won't be able to use alot of cams unless you upgrade to some REALLY big springs.
even the hotcam will become .541" of lift from the standard .525"
a cam in the .580-.590" lift range will be over .600" of lift...requiring a step up to something that can handle .650" of lift.
that's alot
not to mention piston to valve clearance problems could come about
that's alot
Hey you know what, this board won't let you post a reply that is only 2 characters long.
