1.7rr or headers?
1.7rr or headers?
I'm gonna be doing one or the other within the next month unless something else breaks on my car. The headers that i'm going with are the as&m headers and i'm gonna do a single cat conversion. I know the 1.7rr install will be cheaper and easier to do. It will probably show about the same amount of power to the wheels also. What do you think i should do first?
drewstealth NICE dyno numbers. Honestly, if I was in your shoes I would do all the basic bolt-ons to my car before attacking the internals. Besides, IF I am not mistaken you will get more power out of headers anyway, and the car will sound better. Just my .02, some people mite think diffrently then me Good luck.
The headers and 1.7's aren't directly comparable. You can't say each one will give you x hp/tq, so doing either get you what you're looking for. A valvetrain that wants to breath more will need the supporting roles of the induction and exhaust to be up to the task, right? So.. I'd say get the headers, then the valvetrain upgrades.
Well i wanted to save up and get headers. But for less money i can get the 1.7rr's and a cutout. But i guess your right about the breathing part. I will probably save up for the headers. NVetro your dyno #'s look good. But you have a lot more torque then i do. What do you think got you that? Did the tuneing seem to help any?
Do the headers first. It makes no sense to bring more air into the equation if you can't efficiently dispatch the gasses with the current setup.
Plus, with the headers, the rocker gain will be better.
We know that the stock exhaust manifolds are a restriction and that by going with tubes we can lessen that restriction and realize gains.
What I haven't seen to date is the benefit of going with 1.7RRs compared to 1.6RRs on the stock cam, so for those of you who have empirical evidence of the respective gains, please share with the rest of us.
Going with a particular ratio w/ a cam with a particular profile obviously changes the lift numbers as well as the amount of duration and I would assume that the resultant lifts and durations would be part of the planned performance. But just throwing on different ratio RRs with any cam might not prove to be worth the cost/effort and perhaps may even be impractical given the results.JMHO
to everyone that posted in this thread. if you havent seen it, do a search and youll find my thread about my 1.7 rocker install including everything i used with part#'s. on a stock cam these will not make contact with the valve covers and...here is the proof of an increase of 15 rhp on a lt4 hot cam lt1 in a vette on a dyno......vette dyno results
Now correct me if I'm wrong, but that was with ported heads too on the vette.
Also, for MattysTA, have you hit a dyno or been to a track yet?? I've got everything ordered but the rockers, just didn't have time yesterday to order them. Soon hopefully.
