1.7rr or headers?
Old 11-01-2003, 03:32 PM
  #16
MattysTA's Avatar
Originally posted by drewstealth
What did you run with all your mods now? All i see is the 13.5 but that is before all your other mods.
i havent made it to the track since the other mods(like a year now) so even if i did go, it would be pointless to post the results since i didnt go before the rockers anyway...i have to fix my sig cause i wont be hitting the track again untill this trans is fixed. i dont want to go there and run the same time in my sig but with more mods because of my trans........it sux because i really miss it
MattysTA is offline
Old 11-01-2003, 03:49 PM
  #17
drewstealth's Avatar
I know you haven't made it to the track but what did you get with your tazzo?
drewstealth is offline
Old 11-01-2003, 04:10 PM
  #18
Fastbird93's Avatar
Originally posted by MattysTA
i havent hit a dyno or went to the track yet for 2 reasons. 1 i am at work more than im home. and 2. i wouldnt go anyways because with the trans now slipping as bad as it has become i dont think i would make it home without a flatbed.... what i did do was use my tazzo like i posted in my thread. it was on the same road with the same weather conditions and the trans was still slipping just not as bad at the time and shaved off 4 tenths before and after. a tenth of that would be due to the change from a 2.2 60ft to a 2.1 60ft. i know its hard to accept that it made a difference, just because i didnt go to the track doesnt mean anything. the only difference between the street and the track is timers and trackbite....... if it didnt do anything then how did sar2k manage to go a best of 11.9 with nothing but boltons and 1.7 rockers.......
Hey, I'm not placing doubt or any disbelief at all on the 1.7's. Heck, I'm switching to them myself on my 224/230 car. I was just wondering if you had any new updates. I remember from your other post that you said it took .4 off of your Tazzo times, which may seem like a bit much, but you did also cut your 60' down too as stated. I totally accept that it made a difference. That's why I'm dropping the cash on the swap after buying 1.6 Comp Pro Mags when I did my head and cam package about 3 months ago.
Fastbird93 is offline
Old 11-02-2003, 12:55 AM
  #19
MattysTA's Avatar
Before:
60ft-2.37
1/4-13.91
mph-103
After:
60 ft -2.28
1/4-13.52
mph- 106
MattysTA is offline
Old 11-02-2003, 12:59 AM
  #20
MattysTA's Avatar
Sorry for coming off defensive if i did... i would love nothing more than to get some track times with my current setup but its not gonna happen with the trans the way it is so it will be in the spring sometime. when i do ill dig up my thread and post my results....i would watch out for valve cover clearence using those with that cam...........
MattysTA is offline
Old 11-02-2003, 04:33 AM
  #21
So your best was a 13.5 with full bolt on car plus the 1.7rr's? That just seems a little high to me. Is it because of your altitude or something?
Old 11-02-2003, 09:01 AM
  #22
MattysTA's Avatar
yes right now it is, But its only because my trans is slipping pretty bad, and it bounces off the revlimiter like 3-4 times every shift...not to mention it is also spinning quite a bit more.......
MattysTA is offline
Old 11-02-2003, 10:18 AM
  #23
94GrayV6's Avatar
Yeah drew, take a look at Matty's 60' time...2.28 isn't so hot. If he could cut a 2.0 he'd be around a 13.0.
94GrayV6 is offline
Old 11-02-2003, 10:29 AM
  #24
MattysTA's Avatar
i honestly believe with a good trans,nice convertor and a high flow y-pipe i would be able to do mid 12s np on et streets......
MattysTA is offline
Old 11-03-2003, 10:21 AM
  #25
Fastbird93's Avatar
Originally posted by MattysTA i would watch out for valve cover clearence using those with that cam...........
I was thinking about that, but decided it's worth a shot since I really don't have the lift where I want, and I don't want to do a cam swap to get the lift and pick up another 6* of duration either. If the stock valve covers won't work, then I'll look at a set of LT4's or some custom fabricated ones.
I think I might be OK though because when my H/C got done, the mechanic completely clearanced the stock covers out. No more supports to get in the way. Just gotta order the rockers, slap them on, and see if it works.
sherwinZ28
11
08-15-2015 05:38 PM
colts0455
07-28-2015 11:28 PM
jbc3
07-28-2015 12:24 PM
Strick
07-14-2015 07:28 AM
Quick Reply: 1.7rr or headers?
