1.7RR + Stock Cam = Specs?
Re: 1.7RR + Stock Cam = Specs?
Thanks, I appreciate it.
I'm actually putting on some ported AFR 195cc heads that come with some springs that can handle those lift numbers. I'm thinking about still upgrading to some beehive springs and a Hydra-Rev kit for when I eventually do the bottom end. I'd like to do the cam now also, but am afraid of spinning a bearing on my original 130k mile motor. This way the heads would be ready for when the new short block (eventually) comes.
I'm also pondering if I should upgrade the lifters now, or wait for the cam.
Too bad short blocks don't grow on trees.
Brandon Wittmer
12-20-2014 09:51 PM
