#1 cylinder not firing! (continued from other thread)
#1 cylinder not firing! (is it the opti?)
Well Ive known that my #1 cylinder was misfiring because the exhaust header would be cold at start and the others would be boiling hot...
So heres what I did...
1. Changed the plug/wire... plug was fouled and only 2000 miles on it http://img.villagephotos.com/p/2002-.../Photo0060.jpg
2. Did a spark test by just bumping the starter, #1 got a spark
3. Thought it was a stuck fuel injector so moved #1 injector to #3... #1 still misfiring
4. Wanted to try a spark test again so I unpluged injector #1, had the #1 wire on the opti spark on a plug, grounded to the frame.
What happens? It only gets spark when the car is first cranking up, after that no spark at all!!
We tested out #3 and it gets spark all day so its not a ground problem ...
So im assuming my optispark CAP is bad? Would it be best to replace everything or just the cap? Optispark has original 47k miles
Damn opticraps!!!
Damn opticraps!!!
EDIT: Nevermind, I didn't realize that you said it stops getting spark. I would guess opti also. I would replace the whole thing.
Is the PCM telling the #1 injector to fire? Check the fuel injector connector with a noid light. They are like $3 at any autoparts store.
It has spark
It has fuel pressure (since the rest of the injectors work right?)
# 1 injector is fine (it works if in another spot)
so maybe there is a bad connection and the #1 injector is not getting a signal to fire.
If it has good spark, fuel pressure, a good injector, and a signal to fire the injector, I would reccomend a compression leakdown test.
hope this helps
Dustin
It has spark
hope this helps
Dustin
carguyshu
01-22-2017 11:19 AM
Magenta_Hearts
03-05-2015 07:01 AM
ChrisFrez
11-30-2014 08:41 AM
