10 bolt talk!
10 bolt talk!
I know, i know, replace it! If only money grew on tree's.
Heres the question at hand.
As of last season, i managed to go threw 2 sets of rear tires in the span of 5 months somehow . Towards the end tho the rear would peg leg, one wheel wonder..etc pretty bad. No abnormal noises or anything though so thats good ! I can only assume the posi unit is getting worn from my excessive beating on it.
I would enventally like to go big with this car with a stroker engine or a boosted 355, however whether or not that will actually happen is unknown.
I may just throw a 150shot on it and call it good
Now the question i have is, should i just replace the posi, throw a new cover on it, and call it a day?
Or should i not bother, save up and replace the rear end all together.
EDIT: 97 lt1 camaro 6spd with bolt on's. exhaust, tune, headers..
If you can get a different rear, or keep replacing yours. A boosted 355 is going to show that 10 bolt who is boss. Also, its a six speed even more risk of shattering that 10 bolt like a stick.
There is one "alternative" a thread in the drivetrain section called "bullet proof 10-bolt". You can look into it if you want, I do not know much about it.
Being that it is a six speed I wouldn't put much money into it because a few 4k+ rpm launches and that thing will most likely shatter. But I have heard of some going 10's with an auto on the stocker
ChrisFrez
01-18-2015 08:05 AM
1LEThumper
07-14-2003 12:45 PM
