For 100 extra my head guy said he will port the bowl area, worth it?
He said that most of the restriction in the LT1 head comes from the bowl area, and for 100 extra on top of the work I am already having done (milling, valve job, etc), he will really work that area over.
Should I do this if I am planning to run a hotcam or larger when it goes back together?
-Thanks
-Thanks
Re: For 100 extra my head guy said he will port the bowl area, worth it?
agreed. Ive been told the same thing, as in all small chevy heads. and the area wheer it transitions from port to bowl area needs wideningon the side w/the angle. one side will be pretty flat/straight, the other side has a major turn. good luck. have him do before and after flow sheets for a little more. good info to know.
yeah, i'm in the process of doing mine, theres alot of stock there that could be shaped in many different ways, like mentioned above do it if the guy know's what he is doing. it's worth the time it takes for sure!
ChrisFrez
12-15-2014 03:09 PM
Bearmans
12-03-2014 05:28 AM
