110 mph shut off?
Old 06-29-2010 | 01:05 PM
yungmula's Avatar
110 mph shut off?
on my camaro i guess i have the 2.73 gears which is why i have the 110 speedometer but is there a way to bypass that w/o getting a hypertech tuner?
Old 06-29-2010 | 01:44 PM
n2ceptor's Avatar
What year f-body???? Most have to be programmed out...
Old 06-29-2010 | 01:45 PM
yungmula's Avatar
it is a 1994 z28
Old 06-29-2010 | 02:08 PM
It wasn't the gear ratio, it was the speed rating of the tires it came with. Reprogramming is the only way to change the speed limiter. Consider a mail order tune rather than a Hypertech (especially don't buy a new one-waste of money).
Old 06-29-2010 | 09:10 PM
koolaid_kid's Avatar
The setting is in the tune, and must be retuned. You have an A4. If you can pick up a HPP for extremely cheap, it will let you change the top speed limiter, gear ratio, tire diameter, shift points, rpm limiter, etc. Otherwise, either get a tune or purchase a tuning program and open the world up to you. The "performance tune" in the HPP is a joke, I tested it myself and found no difference at the track.
The tires and the gear ratio were tied together, IIRC. If you got the performance package, you got a 3.23 ratio, high speed tires, and a higher top speed limiter. But that was a long, long time ago, and my memory has faded.
Old 06-30-2010 | 12:59 AM
charliediss's Avatar
They made Z-28s with a 110 speedo? lol.
Old 06-30-2010 | 07:51 AM
n2ceptor's Avatar
If the Z28 did not have the Z rated tire option, then yes........
Old 06-30-2010 | 08:50 AM
Mswezey's Avatar
From: Wichita Falls, Texas - College. DF-Dub, when not in college
yeah my 95 Z had it.
Bought the 155mph speedo off of member here or ebay? i forgot
easy swap though! still need the limiter tuned out. but that can wait till later
Old 06-30-2010 | 11:50 AM
red94chicken's Avatar
i had a 94 trans am with a 2.73's and a 110 speedo. it wasn't speed limited that i knew of. i had swapped the rear for a 3.23 rear and the speedo read a little faster then you were going but i have had it pretty well up in rpms in 4th gear and it never shut off speedo was buried. on a track of course..
Old 06-30-2010 | 12:45 PM
CamaroFbody's Avatar
93 z28 6 speed car here..car has factory 2.73s and 110 speedo.
Nayr
03-03-2023 08:34 PM
RUENUF
03-13-2016 03:37 PM
4586
08-18-2015 07:08 AM
Henson071
08-04-2015 09:32 AM
Jcastro2333
07-27-2015 09:49 PM
Quick Reply: 110 mph shut off?
