12 bolt abs question
Okay I am in the market for a 12 bolt but I am unsure what kind of abs I have. Is it a 3 or 4 sensor abs system? I do not have the car right here so I can not go look at it. It is a '93 z with 3.23's.
I am not exactly positive, but my car which is 4 years newer doesn't have traction control and has the 3 channel ABS on the Moser 12 bolt.
Your only sure fire way to know is to look at the rear end. If there is only one sensor on the diff housing then its 3 channel, but if there is a sensor on each wheel then it's 4 channel.
As Injuneer said your car has the 3 channel system. There is a single sensor that plugs into the top of the pumpkin. Remember to remove the sensor off of your ten bolt and install it on the 12 bolt. The Moser will NOT come with this sensor installed.
Sergio
01-27-2016 04:27 PM
ChrisFrez
01-18-2015 08:05 AM
squarehead
01-15-2015 07:02 PM
ChrisFrez
01-11-2015 03:47 PM
