17" wheels wont affect odometer will it?
When you put in a larger wheel in the mix you just drop the aspect ratio and the tire is the same size overall. The 1st number for example in a 275/40/17 is 275, thats the width of the tread in mm. The next number 40 is the aspect ratio, so the height of the tire from the wheel to the outside of the tread is 40% of 275. Get it? The last number, 17 is the diameter of the wheel. Hope that makes since. -Brad
jasonduaine
06-04-2015 09:29 AM
canbaufo
02-24-2015 10:27 AM
