1993 lt1, new msd opti spark and new time cover seals
my 2 year old opti just went out AGAIN, and i am replacing it with a new MSD opti spark, i will be doing it myself this time, i took all of the parts off right now (WP, WP seal, crank pulley and hub, old opti) and am planning on replacing the seals, is there a seal for the opti on 1993 non vented ones? how can i get the timing of the opti right, i did open my old one before i removed it and marked the location of the rotor, new MSD comes completely assembled, so do i have to open it and make sure the rotor is in the right location, is there an easier method?
any help would be appreciated!
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
Re: 1993 lt1, new msd opti spark and new time cover seals
Unless you've already purchased the MSD opti, I would suggest you consider going with AC Delco or Delphi.
You should open your shiny, new MSD Opti (and any other brand Opti) and loc-tite the rotor screws, or you'll be back here in a few weeks asking why your engine is misfiring or won't run.
does anybody know how to install front crank oil seal, is there a tool out there?? plus am planning on using otvc spark plug wires, this is the first time am changing the plugs on my 93 z28 so any advice on how to do it. is there a complete posting on how to do this??
any help?? any one, is there anybody who change their front crank seal on lt1 engine, and used otvc spark plug wires who can help me out
The crank seal must go on straight, flat and true. There are seal installer tools, but most probably just use a block of wood and a hammer. Sometimes it is difficult to get started. Going straight on is the most important part. If the seal gets bent, it is ruined.
thnx for the reply i think that is the problem too it is very hard to install this seal without a tool so i bought KM J-35468 Timing Cover Aligner & Seal Installer, hope this will make it easier to install, am planning on redoing it this weekend hopefully get the tool and the new seal shipped by then, as well as my over the valve cover spark wire kit and start driving my car again. prob thinking for the next is to put a cat back maybe borla, and i would've change to long tube headers but heard it is very difficult to do, it took me 8 hours to change my exhaust manifold to pacesetter headers on my 2004 monte carlo.
BTC... Are you recommending against the MSD?
gce I would say he is. The ac delco and delphi tend to last the longest and have the fewest issues.
Posted from Camaroz28.com App for Android
I don't have any personal experience with their optispark. I considered buying one several years ago when I pulled my car out of storage and began the arduous task of getting it running. In hindsight, I'm glad I let myself be talked out of buying one in favor of an OEM(Delco/Delphi) opti.
I also have over the valve cover wires. I guess they are supposed to be nice if you have headers, but I'm not sure I would do it again. I would probably just route the wires under the headers and use as many zip ties as necessary to secure them. I used all MSD components, plus Made For You looms, and measured and made my own wires. It's not really that difficult.
After going through 2 OEM optis I decided on the MSD. Remember, this is a 93 & 94 and is not vented. The MSD is vented AND has and adjustable spark advance. The MSD woke up my LT1.... Now, maybe my old unit was really weak, I don't know but I do know that the seat of the pants feel was a huge surprise! Sadly I had an oil seal leak after installation and it got into the MSD unit and rendered it useless. But MSD replaced it under warranty and life was good again. I would recommend the MSD Optispark over the OEM.
And anmar A... be real careful with the seals. There are post here somewhere dealing with the seals in the timing cover. And yes, replace the timing chain. The Cloyes C-3228 is the OEM that everyone seams to like. Cheap and reliable.
i will be working on my car this weekend, i replaced all of the three seals, so planning on putting everything back together. why should i be replacing the timing chain, my car has only 116K miles on it.
i dont think there would be any hp gain out of changing the timing chain??
No Hp gain unless it were real bad i suppose, but you are right there, I did mine at 140,000 miles when I did the MSD install. It was not real loose but it was loose. I've read that no one hears of the stock unit "failing" but they do stretch and wear. It's about $100.00 and like I said, you are right there.
But, I believe removing the timing cover may disturb the oil pan gasket... Mine seams to have developed a small leak at the front of it, have not had a chance to really look at it or talk to my mechanic about it.
Anyway, have fun today! Post how it all turns out!
