1993 z28 vaccum diagram
Old 05-19-2015 | 06:53 PM
z28cam1993's Avatar
Hi. Can't find the specific diagram for my year. I'm changing the aftermarket fuel regulator back to stock and need to know what the vaccum lines are located. Some of mine are disconnected and or rotted. Thanks
Old 05-19-2015 | 09:32 PM
Re: 1993 z28 vaccum diagram
Do you not have the emissions sticker still on the radiator cover? It shows all the lines.
Old 05-19-2015 | 11:33 PM
z28cam1993's Avatar
No. Nothing is there. Specifically I need it because i think there is one missing from the end of the fuel regulator. Maybe it fell down or its in wrong spot. This is a car I just bought so i will remove this aftermarket one and go stock
Old 05-20-2015 | 09:55 AM
It should definitely be hooked up to a vacuum port. 93s are different and I can't find a picture or diagram of exactly where it goes. Post 93s are like this. Yours may go to a port on the driver's side of the intake.
Old 05-20-2015 | 01:10 PM
The 93 factory manual shows there are two vacuum fittings on the passenger side of the intake manifold, identical to the 94-97. Given the fact the 93 fuel pressure regulator is on the passenger side rail, above and to the rear of these fittings, I'd bet it connects to the same port as the 94-97's.
Old 05-20-2015 | 06:30 PM
z28cam1993's Avatar
Ok that helps a lot. Thank you
Old 05-20-2015 | 10:32 PM
Fred, isn't it that way on Corvette's? I thought the 93 F-body regulator is on the driver's side front.
Old 05-20-2015 | 10:36 PM
z28cam1993's Avatar
Mine was one the back of passenger side fuel rail. Pain to get off but I did. Aero motive and it is junk
Old 05-20-2015 | 10:41 PM
Ok, cool. I guess I had a wrong picture in my head.
Old 05-20-2015 | 10:44 PM
z28cam1993's Avatar
Well unless someone relocated it to the rear. Ha
Old 05-20-2015 | 10:55 PM
I should have realized this from the fact that the 93 intakes don't have a fuel rail crossover in the front, so the 93 rails have to crossover in the rear. I don't look at many 93s.
Fred's never wrong.
Old 05-20-2015 | 10:56 PM
z28cam1993's Avatar
Yea. This is my first 4th generation and LT1 are another breed altogether. I'm learning a lot since joining this site.
camy 1993
02-01-2015 07:16 PM
CobraEatr
07-24-2004 11:37 AM
teedoff59
08-08-2002 01:36 AM
CobraEatr
07-23-2002 06:32 PM
CobraEatr
07-22-2002 09:49 AM
Quick Reply: 1993 z28 vaccum diagram
