1993 Z28, white smoke on startup
Old 08-13-2024 | 02:26 PM
tadimal1's Avatar
Sorry if this is the wrong forum for this but I did not know where to put this. When I start the car smoke starts to come up from somewhere below and behind the alternator. It some what looks like it's coming from off the exhaust manifold but I could not tell. I do not believe it is coming from the alternator itself but somewhere below. The coolant and oil levels are perfect and I don't think it's leaking anything.
Old 08-13-2024 | 03:55 PM
Re: 1993 Z28, white smoke on startup
What does the smoke smell like? Definitely a difference between the smell of coolant (sweet) and overheating/burning electronics.
This is an acceptable topic for "LT1 Based Engine Tech". I'll move it there for you.
Old 08-13-2024 | 04:12 PM
tadimal1's Avatar
Smoke smells like burnt plastic
Old 08-13-2024 | 06:31 PM
Is the A/C compressor working OK?
Old 08-14-2024 | 01:57 PM
tadimal1's Avatar
Yes, the AC compressor is working good
Old 08-14-2024 | 02:32 PM
Might be an issue with the A/C compressor electromagnetic clutch pull-in. Hard to tell based on the description. Not my area of expertise.
Old 08-15-2024 | 07:45 AM
...or could be a plastic bag that got stuck on the exhaust pipe...
Old 08-15-2024 | 12:21 PM
Chimera96's Avatar
OP, you are much closer to the car than we are. "plastic" smell may be something stuck or touching the exhaust manifold. You need to look carefully from top and under car for "something" (plastic bag you ran over). With that said that type of thing would burn off fairly quick....so confirm some part is not failing and burning.
Take your belt off to confirm all pulleys and accessories spin freely
leaking valve cover gasket dripping oil on exhaust...but that smells like....oil
Old 08-15-2024 | 02:45 PM
tadimal1's Avatar
Thank you for the advice I will check the pulleys and accessories.
Old 09-12-2024 | 01:45 PM
Did you ever find the source of the smoke/smell?
Old 09-12-2024 | 02:47 PM
tadimal1's Avatar
There a lot of oil covering the underneath of the car so it's probably a leak but the oil level seems fine
redz28camaro
07-28-2010 06:46 AM
spyder24
05-08-2009 08:58 PM
saltydog
10-03-2005 12:12 AM
GpMike24
11-25-2004 01:23 AM
xstar
V6 Tech
06-20-2003 06:24 PM
Quick Reply: 1993 Z28, white smoke on startup
