1994 LT1 timing set.... advice needed
Need a timing set for the '94 Corvette. Looking for the best quality that is a direct bolt in and will work with the stock timing cover and '94 Opti. I will also be using a stock mechanical water pump. What timing set should I buy?
1LEThumper
07-14-2003 12:45 PM
