1995 - No Spark, No Fuel
I am getting no spark and the fuel pump is not kicking on.
The computer was replaced after it shorted out the battery. The computer was full of water from the prom cover not being tight. Replaced computer with a new one. Still no spark or fuel. Tried connecting the laptop for pcm signal but no signal.
Any advice?
Any advice?
I had the pcm ign fuse not making contact before yet fuse was not blown. I had same symptoms fuel pump not kicking on and could not connect to pcm.(didnt check for spark) Might be worth double checking the 2 pcm fuses and even testing for power in the fuse box. Have you had it operating correct after changes?
Posted from Camaroz28.com App for Android
Garcia5
07-07-2022 06:51 PM
10-31-2016 11:09 AM
07-04-2005 05:00 PM
