1995 z28 having trouble
I'm having trouble understanding what's going on with my 95 z28. First off is having a hard time accelerating and is stuttering and has a weird rattle at low rpms till about 2-2500. So I got the codes ran a while ago and had code 32, I changed the EGR valve a few days ago and now I'm getting code 32 still and also codes 29 and 48. I read that 29 is probably just the air pump fuse so I checked it and sure enough it was blown so I swapped it. Code 48 is maf so I tried the unplugging trick but no difference. What else could I be getting code 32 for? Why is my car stuttering? Also I have a weird sound coming from the rear right at low speeds (especially noticable in parking lots) and when I get on it from a start or the 1st to 2nd shift there's a hard clunk from the right rear as well.
Re: 1995 z28 having trouble
I don't get it.... you deleted this thread because it "wasn't getting any attention". Yet you double posted, and received "attention" to the other post. Then you never bothered to follow up.
https://www.camaroz28.com/forums/lt1...9-48-a-888457/
aaron_depue
9
12-11-2006 06:31 PM
camaro81
04-16-2006 10:39 PM
Rino1313
07-18-2002 05:16 PM
