1996 optispark, plug and wires replacing
Old 01-11-2021, 07:13 PM
  #16
Re: 1996 optispark, plug and wires replacing
If the dowel pin is in the correct slot, that is all that matters. If it was in the wrong slot you should at least get some popping or backfiring when you try to start it. The spark timing would be off. I've seen/diagnosed cases where the pin was a bit too short, slipped out of the correct slot, and the engine was still starting and running somewhat normally.
Have you checked the fuel pressure?
Injuneer is offline
Old 01-11-2021, 10:16 PM
  #17
mrmint69's Avatar
If you don't have a fuel pressure gauge, do you hear the pump running when you turn the key but don't try to start it?
mrmint69 is offline
Old 01-16-2021, 12:19 PM
  #18
tzagacki's Avatar
no gauge yet I do hear pump when turning key just short of start position
tzagacki is offline
Old 01-16-2021, 01:07 PM
  #19
When you turn the key to the “RUN” position, the fuel pump should run for 2 seconds, and shut down. Should produce at least 40 PSI. Pressure should not bleed off quickly.
The pump will not restart when the starter is cranking the engine until: 1) the PASS-Key (VATS) system sends the “fuel enable” signal (50 Hz square wave from BCM) to the PCM, and 2) the PCM sees the low resolution cam position pulse signal from the optical sensor in the Opti.
Injuneer is offline
Old 04-22-2021, 11:59 AM
  #20
tzagacki's Avatar
please advise where valve is located to test fuel pressure, thought it was along drivers side of fuel rail. TZ
tzagacki is offline
Old 04-22-2021, 12:10 PM
  #21
TampaGuy's Avatar
Courtesy of Rob...
http://shbox.com/1/fp_reg.jpg
TampaGuy is offline
Old 04-23-2021, 01:22 AM
  #22
tzagacki's Avatar
thank you, know what size valve for testing?
tzagacki is offline
Old 04-23-2021, 10:24 AM
  #23
Fitting is -4AN
Injuneer is offline
Old 04-25-2021, 02:51 PM
  #24
squarehead's Avatar
OP,
I scanned this thread and don't see any error codes listed. Did you check for codes? Is the check engine light on? I learned (from Fred!) long ago not to try to diagnose these cars without a code reader.
squarehead is offline
Old 05-29-2021, 06:14 PM
  #25
tzagacki's Avatar
tested pressure, spiked at 43 to 48 psi initially, held at 40 pounds, slowly bled off after five minutes pressure was down to 38 pounds
tzagacki is offline
Old 05-29-2021, 06:50 PM
  #26
tzagacki's Avatar
any tips on testing coil?
tzagacki is offline
Old 05-29-2021, 09:43 PM
  #27
Continuity test:
http://shbox.com/1/coil_testing.jpg
Injuneer is offline
Old 05-30-2021, 10:01 AM
  #28
tzagacki's Avatar
thanks!
fuel pressure readings are okay?
tzagacki is offline
Old 05-30-2021, 11:10 AM
  #29
tzagacki's Avatar
different coil and meter from picture that was sent
tzagacki is offline
Old 05-30-2021, 12:30 PM
  #30
Shoebox’s photo is a 94/95 coil with 2 connectors. Yours is a 96/97 coil with a single connector. Internally, the wiring is all the same. Just probe the 2 pins in your single connector the same way shown in the photo. The exact resistance isn’t important. You are just verifying there is no open circuit.
94/95:
http://shbox.com/1/95_ign_system_schematic.jpg
96/97:
http://shbox.com/1/1996_ec_03_ign_system.jpg
The photo was not intended to tell you that you had you had to use the same brand/type of meter. Your appears to be set on 25 Kohms, so that's all that matters.
Fuel pressure is OK.
Injuneer is offline
Quick Reply: 1996 optispark, plug and wires replacing
