1LE A/C Delete Pulley
#17
Re: 1LE A/C Delete Pulley
635k6 just went through this mission the stock belt was to loose and slid right on to the steering pump i got the above mentioned one and it works great just enough tension not to tight though.
btw: i am not running any other pullleys i am running stock ones.
#19
My problem is exactly the opposite, the belt is wayyyy too tight and as soon as you turn the ignition key off the motor clunks to a stop. Just need to get off my *** and take the belt down to advance and find one a lil longer.
