2000 miles after switching to synthetic
this is probably hard to answer with any certainty...but after the cleaning effect synthetic has on old dyno oil gummed seals...think I am out of the woods? as far as leaks?
the Lt1 engine & tranny in my car after Mobil1 10w30 motor oil and Mobil one synthetic tranny fluid used starting 2000 miles ago there are no leaks...at all
I have heard that synthetic may actually cause more leaks, due to the fact that more gunk in dyno oil would mean more sealing power too. I switched to synthetic after I bought my car and frankly, I haven't noticed much of a difference. There was a slight leak in the front somewhere, and it's still there. Not really enough to bother with.
If it's a bad leak you might as well find out where it is and replace the gasket/seal. It's the same concept as a leaky radiator. Stop leak fluids may work for a while, but the leak will be back, and your system might get clogged up as well.
If switching to synthetic actually stopped a leak for you, then congrats, you've got better luck than I do.
I thinked you missed the question..lol or...i missed the answer.
I dont have any leaks after switching to mobil one synthetic 2000 miles ago...think I am out of the woods???? and now I can feel assured it isnt going to leak, at least from oil related .
Oh Ok I get it...
Yeah it sounds like you're safe... for now.
I will say that engine will spring a leak- it's just a matter of when. Very few people's LT1s actually never have any leaks, but at least switching to synthetic didn't cause you any problems...
