227/233 starting problems w/o tune??
Just curious if anyone else has had a problem with the car running after installing the 227/233 cam from CM. We just finished the cam install this weekend and it cranked up just fine and drove it 30 miles. Well the next day I start it up to check the oil and it ran. 5 minutes later she wouldn't start. Just wondering if the stock tune is causing this. By the way its on stock heads and went ahead and installed some SVO 30# injectors too. Im waiting on the tune from PCM4Less as we speak. It's an auto too.
Re: 227/233 starting problems w/o tune??
Well you can't run a stock tune with 30# injectors. They will foul up your plugs. Just wait until you get the tune and also check your plugs and replace if necessary.
The reason for the injectors was to get ready for the heads in the spring time. As for it running it on a stock tune well it doesn't run so no prob. there. I got my tune in so well see what happens tomm.
10-31-2016 11:09 AM
