3/4" or 1" header bolts with RKSport headers?
#16
Re: 3/4" or 1" header bolts with RKSport headers?
Originally Posted by mkent
To be honest, the AS&M's are probably not worth the extra $300. Everyone in this thread has described every detail I had to do while installing my AS&M's. They were a huge pain to install but they are pretty when they're done. For the money, I was unhappy with the fitment. I later helped install some MAC's and they were so much easier to install.
Did you encouter the following problems on the AS&M's:
1. Steering shaft hitting the primary
2. Right header collector hitting the k-member.
3. Y-pipe not pent perfectly for install.
4. Bolts hole did not line up perfectly?
#17
Originally Posted by wrd1972
Well thats good to know too. I am very happy with how these RK's look.
Does this Y-pipe follow the original geometry of the stock Y? (Will I be able to bolt the cat up in it's original location or will things need to be moved around in order to do that?)
#18
The RK y-pipe follows the same routing, however I had to bolt the larger pipe to the work bench, heat it at the bend closest to the flange and lift it about an inch. Then I had to cut an inch of tubing off where it fits into the Y-fitting.
It owuld have been impossible to install the y-pipe without these mods.
I did not re install the factory cat, I bought a magnaflow high flow cat and a ball flange so it bolted directly up to the y-pipe flange and the Borla ball flange.
I also used aluminum collector gaskets instead of that paper junk that came with the headers.
#19
Yeah I plan on that as well, I was looking at the Random Tech.
Just wondering if it was going to be able to tuck up under the floor hump in the usual spot
#20
Okay, so I'm getting
header bolts
header gaskets
collector gaskets
What is the gasket for the Y to cat connection? Is it the same as the collector?
Or is there one
header bolts
header gaskets
collector gaskets
Or is there one
#22
depends if you get it welded there or have a flange. I personally would get it flanged so you can drop it when its in the way of working on something. That being said, you are always more prone to leaks with flanges
#23
The stock setup is flanged, right? It'll probably stay that way to make things easier.
I need a low-profile jack. I want to get under my car to take a look at things and I can't
I need some wood planks at least
#24
#25
The stock cat is welded ot the stock y pipe. A flange connects it to the catback. Its easiest to just go with a dual-flanged aftermarket cat. Not only is it the easiest to install, but you could swap it out for an off-road pipe if you ever wanted to.
#26
BTW, nice avatar.
#27
Originally Posted by ponyackn
You should of told me I would have given you the wood planks in my garage brotha. It's kinda of ghetto but it has come in handy . When do you plan to start working on the headers? After seeing the tires on your car, I think I'm sold on the sumitomos.
BTW, nice avatar.
BTW, nice avatar.
I think we'll be doing it after the weekend. My buddy is a mechanic, works out of his house... So he's gonna help me along with it. Time to get my hands dirty.
94Z28LS1toLT1
04-07-2015 05:37 AM
SavageZ28
17
07-14-2002 11:04 PM
