3.4 to Lt1 Swap wiring problems PLEASE HELP A NEWBIE???
#16
Re: 3.4 to Lt1 Swap wiring problems PLEASE HELP A NEWBIE???
Not sure which one that is ?? can you tell me!! The one I changed is the VATS I was told . The car has power & key turns on the dash all lights up it cranks just no start no Fuel & no injectors . Well get it figured out sooner or later .
JOSH
JOSH
#18
OH MY GOSH , your talking chineese in that post , you got D30 & 120 & pin this & pin that I think I just lost hair!!! LMAO . I have no fricken idea Im going to end up taking this darn car to a shop on a flatbed arnt I .
I can build just about anything work on anything , I build houses , do electrical , plumbing , I build street bikes , ride pocket bikes race dirt bikes , play & build paintball guns , golf anything EXCEPT THIS DARN WIRING ON THIS CAR!!!
WHO LIVES close enough to me that I could pay someone to come over & show me how to fix this wiring!!!
I feel like such a DumbAZZ , Im just lost.
JOSH
JOSH
#19
Well you're gonna have to try and figure it out on your own because I doubt a shop will want to mess with it in its current state.
It's pretty easy really. Do you have a multimeter? You can get one from a place like walmart, radioshack or autozone.
You need to switch it to read DC volts. Then pull out the blue connector from your PCM. Look closely on the connector and you will find numbers on the corners of the connector. This will tell you how to figure out the pin numbers. Then all you have to do is connect one voltmeter lead to one of the pins and one to the other. This will measure your voltage.
Here is a picture of your blue connector. You will want to measure the voltage between #1 and #3 pin (holes) on this connector. Easier?
#20
Nice , YAAAA PICTURES!!!! LOL its like starting from 1st grade , I do have a meeter actuall I think I have 3 dont ask why I just do I think it was from I used to race RC cars .
Ill run the test right after work tomorrow & get back to you thank you again for all the help (Im sure we can get this car running!! This Site rocks everyone on here seems to really know there stuff & thats great.
This connector pic says OBD 2 I thought mine was a OBD1 will that matter.
JOsh
JOsh
#21
Both OBD1 and OBD2 use the plug coloring on the ECM. Shoeboxs site has some nice pictures of the ECM pin-outs and the harness plugs .
http://shbox.com/1/schematics_wiring.html
#22
I didnt get around to checking those wires yet I was so darn busy with work yesterday , I should be able today . That website you sent me rocks Im learning allot with that site WOW thank you!
JOSH
JOSH
#23
Ok I ran all the tests & found on the black PCM connector numbers B30 & B31 had no PCM Battery feed or Ignition feed so I spiced into the wire & added a 12 volt power feed to both on one wire not sure if I can do that but it worked now the car starts but just shuts right off . It wont stay running any other ideas why it could be doing this , Im so excited I got to hear her start up !!!! YAAAA no thanks to you mad wolf
ANyway email me or pm me back please Im ready to hear her run!!!
YOU GUYS ROCK EVERYONE HELPING ME you have no idea how much this means to me . Im starting it with open headers right now I dont have the exhaust done yet & as soon as it started my little motor head of a 4yr old came running out to the garage & was so excited to hear it . My 4 yr old just got back from a 3 month stay in columbus ohio & had a bone marrow transplant he is my little motor head all the way .
JOSH
JOSH
#24
Well everyone Im excited to say ITS ALIVE!!!!!!!!!!!!! I got it started today . I still have to have that jumper wire to the 2 orange wires on the PCM. Remember I said it would run for like 5 seconds & just shut off , well all I did was disconect the IAT in the throttle body boot & the Mas air flow & the car started right up & stayed running weird HUH!!!
Now problem number 2 now my Speedo is burried any ideas here??
JOSH
JOSH
#25
Ill check the injectors but its running pretty good . I have a guy comming over sunday with a laptop to tune the car!!
JOSH
JOSH
#26
Originally Posted by camaroRI
did you drive it on the road yet ?
my **** ran decent with 4 injectors unplugged until i went out on the road.
Ryan
Ryan
#27
Yes all injectors have power & all are working as for taking it on the road no not yet Im scared , LOL . Im waiting for the guy to come over sunday with his laptop & turn everything off that i dont need & then tune it , I dont want to hurt anything.
I was backing in the garage & it jumped out of reverse why would that be its a T56 6 speed & was just completley rebuilt ???
JOSH
JOSH
07-04-2005 05:00 PM
