3/4 past 0 lash for comp R's?
#21
Did you get the plug wires on correctly? When I put rocker arms and springs/wires/exhaust on my friends 95Z, it did sorta the same thing, wouldn't run, popped out the exhaust, I went through the rockers four times, checked the wires thought they were ok, checked them again and had 2 or 3 wires off, suddenly, the car pulls alike biotch. You could have a wire crossed, maybe a vacuum leak or something like that.
When I was having problems, I posted and posted, I got the MT2500 snap on scanner from work, relaying info back to people on the boards, and it was all over a damn plug wire. I felt like an idiot, and I do this stuff for a living.
#22
Wooooohhoooooo!!!! Got her fired Up! I found #1 and 3 spark plugs a little loose and on top of that covered in raw fuel. so I cleaned them off and reinstalled them and Varooom! The only problem is that every 5 sec or so it has a small backfire. It was pretty bad at first but started to clear up more as I let it run. I'm going to go back over the plugs and wires tomorrow. I have the lifters at 1/4 past 0 lash so they should be ok. I'll have more time to let it run later. It's time for bed now though. Thanks everyone for alll of your input!
#23
Oh yea LilJayV10, that was really a really good post...where were you earlier? Just kidding. I really thought that the valves were not adjusted right and before I was abaut to roll it off of a cliff I decided to check the plugs one more time. Good thing.
08-05-2015 08:35 AM
