305 cam swap, rr's, pushrod length
Quick question...I am going to put the 305 cam in my 94 lt1....I am also swapping over to 1.6 rr's....not sure if I am planning to take the heads off or not...but if I don't (and it's all stock) and change this setup, how will the length of the pushrods be affected? I know it's best to measure but I was just wondering if someone had any experience w/ this....thanks.
You would most likely be fine with the stock length. (7.2?) But, you answered your own question, just measure to be safe. For example, the hotcam kit comes with 1.6 RR's and they are made to swap right in with the stock pushrods. I have the hotcam kit going in right now and i ordered the comp cams length checker, but havent gotten that far yet.
Thanks.... 69gto96z, I am thinking about going w/ the .010 thinner head gasket as well....not sure if I'm going to take it down that far or not...I think I'll just get everything on and measure...I was trying to buy a day or two....I guess measuring and then ordering will at least give the sealant on the intake time to set up....haha...
GaJoe i see you got the cam. ha i am ordering a pushrod lenth checker. when i am dune with it its yours . ordering it monday probly be seting the engen up in 3 weeks after that its yours .and use comp cromoly harden pushrods. sary
its late just got back from towers long drive 2 ours there 3 1/2 back. just to see if any one had the le2.2 or le1.5 .to see which i am to use got both selling one .not shore which i am going to use on this engen.sary about the spelling have deslexia and i am beet
oldschool
02-09-2016 09:21 PM
