355 LE Dyno tune this Friday...Guess my numbers
#151
so help me try to understand this, this cam is so hard to control because it has the same lift as a larger cam but with less duration causing the ramp up and down to be much more dramatic, correct?
#152
i have a feeling they at least need to be checked by someone other than who has already checked them
#153
yeah i think what we need is a detailed parts list for all the valvetrain parts including the valves, retainers, locks, rockers and pushrods. i have asked for this before but never got a response
a detailed list wont help...... you can list things off all day long. everymotor is going to be different. Its not like anything is set in stone.
IMO these guys need a milder camshaft, but If springs will fix it then fine. Go for it.....
Its not hard to check rocker tip sweep so anyone with basic knowledge can do it. I really don't see that as a problem. Other than anything being bent Its not a pushrod issue
#154
Not an exact example but is a easy comparison about how the same "lift" at different speeds(rates) is harder to control.
#155
I know for a concrete measurement you need to get down to an actual length test but my "guess" is that he needs a 7.1" rather than a 7.2". That is in no way me giving him advice to go buy some 7.1"s and throw them in there expecting it to solve his issue.
I don't think thats where the problem is.....
#156
I would guess that one of two things is happening.
1. The lifter is being launched off the opening ramp once at the top.
2. The lifter is once it stats to descend, is unable to maintain contact with the closing ramp.
I think its the later. The same lift cam with more duration would lessen the fast ramp issue to some extent I think. Someone correct me if I m wrong.
BTW my pushrod length is 7.000" with dead center rocker pattern on the top of the valve stem face with a moderate overall sweep.
#157
Think of it like hitting a 4" speedbump at 5mph or 10mph, at 5mph it will likely be a smooth experiance, at 10mph you test the bumpstops and need your fillings checked.
#158
.300 too long it would push the tip right off the end of the valve, I don't see anyway it could be that far off. It has to be closer to his needs even if it is wrong. .100 or .150 too long would be very noticable
#160
thats why i wanted a exact parts list, as far as i can tell i have a similar setup but with 7.150 rods, i know every set up can be different but with milled heads and a smaller gasket i have a hard time understanding how he could possibly need a MUCH longer pushrod
#161
but it is easy to make a mistake, from what i understand it is very difficult to measure a pushrod with hydrolic lifters, and if he did do the right thing and make a solid lifter out of a hydrolic in order to test maybe he did that wrong or just made a simple mistake, which is why i suggested he at least have someone else check them at least to be sure
#162
#163
man this is an awsome thread with tons of information, one of the best i have seen in a long time
#164
thank you, that does help me understand it much better
thats what i was thinking too, and why i have a similar cam, but with more duration, and therefor much less problems
I have stock lifters in the car, the heads have been milled, The heads were milled .042, they have almost a .020 thinner than stock head gasket, valves are .050 longer, valve job sunk so that moves everything up even more, 2.00 and 1.60 are the valves, the pushrods are 8308-16 hi-tech 5/16" 7.450" oil restricting from Comp..... , the rockers are pro mags 1.6 rockers 7/16 stud, trick flow guide plates, Pac 1218's beehive springs, Comp cams 10 degree super locks, part #
part#611-16 standard locks 11/32" and of course the B-spec-b4 cam from Bauer racing. is that enough on the parts list or do you guys need more......
#165
