383 build up questions
basicly i got a lt1 pretty modded now.making about 400 hp or more.but want to make a 383 stroker out of it but prepare it for a super charger.im hoping to get over 700 hp but no less than 600.i want to know if any one knows of a kit for like a $1000.i want it to be forged of coarse.and what kind of stroker kit should i get.like spec wise cause ive done a lil shoping and there seems to different kinds of kits.
Re: 383 build up questions
I tried to go the kit route which limited me in choices for connecting rod length etc. Most 383 kits are not set up for supercharger setup (low compression ratios). Here's were I got mine http://www.sdpc2000.com/catalog/3258...Assemblies.htm These kits are in the $2500 range though...
Most companies offer a low compression 383 kit. Eagle includes a 4340 crank, H beam rods, and JE/SRP pistons. You can get them from Combination Motorsports or most of the other vendors.
EAG-12106Eagle SBC Forged Rotating Assembly
3.75 Stroke Crank, 5.70' Rods, SRP -31cc Dish Pistons, PM File Fit Ring Set$1649.97
A 355 with some juice would be a better option for a budget.
$3k is a drop in the bucket when you start talking about a FI build on an LT1. Want to guess how much I have into my 383/T trim setup right now. I sure don't.
Originally Posted by jmh96z28
hey 95z383lt4.what numbers are you laying down off that set up
you make it seem like a 10.5 is no good.thats what i want.a ten second car.how much is your compression.also what would be better.a 383 low compression with low boost or a 355 low compression higher boost.also can i have a 355 with a stroker bottom end
A 355 and a 383 will have the same 4.030 bore. The displacement comes from the crankshaft. 3.75" would be a 383, 3.48 would be a 355.
And the amount of boost you will see will be dependent on the engine you put the blower on. Don't think of it in terms of a number on a gauge, think of it in terms of air flow through the engine. More air = more power. More boost = more heat.
You should thoroughly think through all the aspects of a FI LT1 before you dive in. It ain't cheap to do it right, and if you don't do it right you would be way better of with a "done right" N/A setup.
IMHO, LT1 F-bodys are not the world's best choice for a blower. Really crowded under the hood, among other things. There are only a few I'm aware of that have turned out stellar.
