383 LE2 Discount Dbl Check
#16
Re: 383 LE2 Discount Dbl Check
The F'ndowel pin was loose! It basically came off with the opti..... Clear polishing where the opti wheel was hitting it from both sides as it kept the opti within a 3-5deg. range. Which totally explains why it ran so well for a period when it was probably lodged in a solid position. I've JB welded it back in.
If so, did you check the dowel pin length before installing the Opti? If you are indicating that the stainless steel shutter wheel for the optical cam position sensor was rubbing on the sensor housing, sounds like the dowel pin may have been too long. Was there similar rubbing in the cap, where the rotor was being pushed into it.
I also didn't realize that it was fairly common for an opti rotor to blow up after 6k RPMs which explains my last failure (which was an AC Delco w. maybe 25k).
I wouldn't blame the Opti for what appears to be an installation error.
Suggestions on any solution? MSD, ACCEL, DyanSpark, Cardone, LTCC or otherwise?
You want a GM Opti - AC Delco or Delphi.
#17
Fred - Thanks for hanging in there with me on these.
1. What happened - When I pulled the newly installed opti the dowel on the cam literally came off the camgear with the opti - just slid out of the hole. The dowel showed clear signs of consistent rubbing against the opti wheel like it was loose and hitting the dowel on both sides as it though it had been lightly polished or rubbed clean at two points on the dowel. The dowel length is a non-issue. The dowel worked fine with the previous opti for 5 years. This scenario fits into the mold of running really well for a period and then becoming dislodged or loose and running like complete poo as the opti wheel bounce back and forth within the range the dislodge dowel maintained.
2. What I did - Yes, I JB welded the SOB into the cam timing gear. When I need to remove the gear I may regret that. I'll deal with it at that point. It was a drop of jb on the tip of a screw.
3. The rotor exploded on the PREVIOUS opti (the AC delco unit installed in 2006)which is what started this entire mess. It is possible the rotor issue was from crystallization on the points in the opti. I mention the +6k RPM only because of several instances I've heard others express on this forum while researching the Delteq, Dynaspark and LTCC systems. So you weren't clear on what had happened but "it appears there was an installation error"? -there was no installation error. The pin came loose. Perhaps the gent that installed the dowel on the comp cam back in 08' did a shoddy job but it held for 5 years. I think it's a bit of a fluke but they happen all the time - such is life. I'm extremely **** on my installs. I understand the critical important of this piece (which is why the last one was an AC Delco unit) and literally nestle the SOB into place and no stresses are imposed on the housing when bolts are secured.
4. I fully understand LTCC is not an opti but uses the 2 channel opti signal. I'm not interested in going the 24x route due to current configuration and $ (I've eliminated the crank sensor for the roller chain some time ago). The delteq is dogged on consistently and likely for cause but I was unable to find any specifics on what actually failed aside from the actual circuit board?
Just ordered the Delphi unit. I'm taking the POS O'Reillys provided as GM OEM equipment back (yes I'm Scottish/Cheap I can't help it). Any suggestions on identifying the a Delphi unit? Do the Delphi's have the Mitsubishi optical sensor?
#18
I still don't understand.... how can the dowel pin be loose and bouncing around on the "wheel" (do you mean the cylindrical part with the hole for the dowel pin, and the "extra" holes are located????) and still be pulled out of the cam nose?
You appear to have a 96 with a dowel pin drive, but then you indicated you used JB Weld to attach the dowel pin to the cam sprocket?
Guess it doesn't really matter... you appear to be fully confidant that you have correctly installed everything and have it totally uinder control, so there's not much more help that I can offer.
But just to make sure you know - Delteq disappeared at least 5 years ago, there are no spare parts available and no technical support of any kind. And it was pretty much a POS.... yes I know a couple of people have working units, but they appear to be in the minority.
Good luck.
Good luck.
teal98
15
09-16-2002 01:23 PM
danielbmx
08-27-2002 11:11 PM
johnsocal
21
08-17-2002 01:06 AM
SilverWS6
13
08-14-2002 09:29 PM
newby
10
07-27-2002 11:39 AM
