383 Lt1 Hp
383 Lt1 Hp
I know you guys prolly hate this, but im really curious on what kind of HP im looking at.. Heres the stats : Lt1 .30 over with '400' crank , 383, the crank is a 9000 series 1pc scat crank for the lt1. My pistons are Hypereutectic Aluminum, Dish Top, 4.030 in. Bore. from TRW, connecting rods are eagle SIR 5140 Steel I-Beam, my cam is CC305 from compcams, stock lifters ( prolly should change ) , fully ported/polished gm heads, new springs and valves, 1.6 rr comp, march ud pulley , and a set of shorty hookers. this is actually a carbed motor with a demon 750 cfm on it. Rear gears is 3.23 posi. Tranny is a 700r4, and the stall is being upgraded atm , looking to order a new tq(assuming its a high torque) . The block itself only had about 30 miles on it before i decided to do this project. Please give me your estimate or if any of you guys know someone with some where around these stats im really curious, thanks alot.
10-31-2016 11:09 AM
