383 piston help
383 piston help
I have been looking at different pistons to go with for my desired out come and have talked to a few manufactures about their pistons. Right now it’s looking like JE is the route I’m going to go. I was going to use SRP pistons but they are only rated to a max of a 200 shot of nitrous and I don’t want to be at the very raged edge of what I plan to run. The JE are rated up to 250 so my 200 shot shouldn’t push it.
So here the idea.
58 CC Chamber
5 CC Piston Relief
.039 Gasket Thickness
4.035 Gasket Bore
4.030 Cylinder Bore
Piston in the hole .010
3.75 stroke
6 inch rod
233/239 cam that has a IVC of 45 so (289-233/2)+45 = Advertised Closing of 73
This give me 11.7 SCR and 8.69 DCR.
Is a quench of .049 going to be about right or should I drop it down to .039 by zero decking the block?
Problem is that running a zero deck on the same setup puts my SCR to 12.01 and DCR to 8.92….seems like I might be pushing it for my expertise level of tuning.
For that matter am I silly for leaving the piston in the hole and not going with a different piston all together to achieve the desired CR, DCR and Quench.
BTW, I have an electric water pump and 160 deg thermostat for added info on my quench question.
Any suggestions or insight?
So here the idea.
58 CC Chamber
5 CC Piston Relief
4.035 Gasket Bore
4.030 Cylinder Bore
3.75 stroke
6 inch rod
Re: 383 piston help
So here the idea.
58 CC Chamber
5 CC Piston Relief
4.035 Gasket Bore
4.030 Cylinder Bore
3.75 stroke
6 inch rod
So here the idea.
58 CC Chamber
5 CC Piston Relief
4.035 Gasket Bore
4.030 Cylinder Bore
3.75 stroke
6 inch rod
Your gasket probably WON'T be 4.035 more like 4.100-4.125 unless it's a Cometic $$$$$$
.039 quinch is great-Fel Pro gasket.
8.92 is OK for DCR on pump gas-let a pro tune it.
Call Probe Industries about pistons,they are good quality and good price.
When ya figure in your correct number's AND advertised cam duration NOT@50 ya probably won't be that high on DCR.
Re: 383 piston help
I figured my IVC the way that SStrokerAce described a while back.
(Advertised duration - actual duration)/2 + ABDC = IVC
(289-233)/2 + 45 = 73
What did I do wrong?
No user Twofast4lv on this site.
I'll check into Probe.
BTW if I zero deck the block will my intake need to be worked to fit the setup.
Thanks guys
Any other advice?
Thanks guys
Any other advice?
Re: 383 piston help
Thanks guys
Any other advice?
Thanks guys
Any other advice?
Yes on the intake.
Ya can get Probe to make ya a set of pistons to bring it to zero without decking.
Re: 383 piston help
I'll take a look at my cam card later tonight.
Getting Probe or anyone for that matter to make me a piston for that is a good idea.
I'll just have to get the block prepped ahead of time so I will know what my final deck height (in case it needs more than a resurface) will be before I order the pistons.
gonzo275rltw
09-05-2015 06:26 PM
gonzo275rltw
09-05-2015 06:24 PM
