383(please dont kill me)
Ok, before i beat my topic to death, i got one post i really need everyones help on. While trying to plan out my engine build, i realized, i need a list of every part i need. so my questions is, for you guys to send me a list of parts needed to make a bare block Lt1, into a 400+ hp 383.
i really appreciate everyones help with this. thanks alot. specific parts will be helpful too. sites to get the stuff for cheap, and any other things that will help me in this build.
$Glen$
$Glen$
well, all i need is the basic parts, and any opinions from there on are just for me to review when going to purchase those parts. i kno everyone builds em different. but theres gotta be some kind of schematic for this.
I just bought one done ....400RWHP dynoed....hope this helps
Cam Joe Overton 234/242 .568/.540 111lsa+2
Crank Eagle 103523750
Rods Eagle CRS60003B0
Pistons JE 170817
Caps & Studs Pro-Gram 4 bolt caps
Oil Pump Moroso 22135
Oil Pan Moroso 20205
Timing Chain Cloyes Double-Roller p/n 3145
Lifters Comp 850-16
Rockers Comp 1305-16 (1.6, 7/16 Stud, NSA)
Rocker studs ARP 134-7103
Head studs ARP 134-4001
Valve Spring Locators CC-4705-16
Valve Spring Locks CC-613-16
Valve Spring Retainers CC-795-16
Valve Springs PAC 1518 PAC 1518
Pushrods Lukovich Hardned Premium Nitrided Beehive LS1 Spring
Guide Plate Iksy OD: 1.290'
Valves Manley 2.00 (11500-8) & 1.56 (11501-8) 130 lbs @ 1.800'
337 lbs @ 1.150'
LE2 Heads .2 139/110 Lift: 0.650'
.3 191/141
.4 241/171
.5 271/182
.6 275/191
.650 277/195
28" Flow Bench
Injectors SVO 36lbs
Fuel Pump Walbro PT-W340 Intank 255 Lph High Pressure
Electric Water Pump MEZ-WP118HD
Compression Approx 9.7:1
Pistons JE 170817
Lifters Comp 850-16
337 lbs @ 1.150'
.3 191/141
.4 241/171
.5 271/182
.6 275/191
.650 277/195
28" Flow Bench
Injectors SVO 36lbs
