396 oil pan?
With a 396 you might need an aftermarket pan...the stocker will work with a 383 but requires a little banging....mellings are good replacements but it seems that just the GM stocker with the "white spring" is working just fine for some people.
ok good enough. im buying a kit from nu-tek friday and i guess i'll just go ahead and get there oil pan kit too. It says its made to fit about hooker lt's so maybe this is the best way for me.thanks
96SilverRam
07-02-2015 12:11 AM
