396 Stroker
396 Stroker
Hey everybody, new to the site. Thought i'd tell ya about my 396 stroker i'm in the process of building. I have a race prepared 96 Vette block i bought already machined. Its bored .45 over which cubic inches are 398 now. Bottom end will consist of: Callies Dragonslayer stroker crankshaft, Forged H-Eagle 6" rods, JE .45 over racing pistons, Oliver Billet 4 Bolt main caps with ARP studs and bolts. Canton Oil pan. I sent Bare Trick Flow castings to Loyd Elliott which he worked, Valve sizes are 2.08, 1.625 valves, LT4 intake port matched to the heads, with a Custom cam by Loyd Elliott. 36 to 38lb injectors. All this goin the a 4L60E if it holds up. Anybody else running a 396?
Re: 396 Stroker
A BUILT 4L60E is running in the 8.50's in a 'Vett with a Rossler.
http://www.rosslertrans.com/Sale4l60e1.htm
Re: 396 Stroker
Yea i will be running a 10 bolt for now with 3.73's for now, but i will probably end up gettin a 12 bolt later. And gonna spray a 200 shot on down the road to.
Re: 396 Stroker
Originally Posted by 94Z396_0621
Yea i will be running a 10 bolt for now with 3.73's for now, but i will probably end up gettin a 10 bolt later. And gonna spray a 200 shot on down the road to.
When you get finished and tuned give us a some numbers As you can see in my Sig...Lloyds heads worked great for me........
