4.10 gear in stock carrier?
i have a 93 formula i was wondering if i can out 4.10 gears in the stock carrier if i can just put gears in it now or do i have to buy a new carrier... also what number carrier is stock please let me know thanks...
shawn
shawn
Location: Somewhere between a shotgun barrel, and a blood spatter on the wall.
NO you cannot use the stock carrier 3:42's and lower require the stage 3 carrier unless hell has frozen over and im dumb... you have the stage 2
Shawn What gears do you have in the car now? If you have a 3:?? gear or numerically higher you can install 4:10. If you have anything lower some gear manufacturers also make a 4:10 gear that will work on a 2 series carrier as well I believe Richmond does. The ring gear is just simply thicker. Cost is a little higher though.
10-31-2016 11:09 AM
