View Poll Results: head cam package?
AI 200cc package
16
50.00%
LE2
12
37.50%
other options?
12.50%
Voters: 32. You may not vote on this poll
400+hp on stock bottom end with h/c setup?
Old 04-23-2008, 02:51 PM
  #16
ulakovic22's Avatar
Mail order is Ion (MadZ28) or Brian (PCM4Less). Dyno tune depends on where you are located. I'm sure some members local to you know of someone.
ulakovic22 is offline
Old 04-23-2008, 06:00 PM
  #17
1996camaroSSclone's Avatar
Ok. Anybody have an idea on what stall rate would be good with a vigilante on stock engine with AI 200cc h/c in the future?
1996camaroSSclone is offline
Old 04-23-2008, 06:25 PM
  #18
speed_demon24's Avatar
Depends on the rest of the setup. That would be something to discuss with Ron or Phil.
speed_demon24 is offline
Old 04-23-2008, 06:32 PM
  #19
96capricemgr's Avatar
I am running a heavier car and the converter is setup to launch hard since the chassis will handle it but I have a 3400 Edge. You could go with Edge Yank Vigilante all are good and say 3200+ stall higher would be better for the strip IF the car can plan the power.
Was a time when I was afraid of stall but once I had experiance with QUALITY torque converters I found it is just fine. Wife actually likes to drive the car, when I had a 2800 and 3.42s in it passengers mistook it for stock at low speeds, abrupt application of the skinny pedal corrected them.
96capricemgr is offline
Old 04-23-2008, 06:40 PM
  #20
With 4.10 gears I'm thinking about 2800-3200 stall wether it be yank, vig. or edge.
Old 04-23-2008, 06:52 PM
  #21
tireburnin's Avatar
Depends on the intended use of this car. If you want better track numbers, you need a higher stall (in most cases). I would go 4-4200 if this is a weekend "fun" car. And 3400ish if it were a daily driver.
tireburnin is offline
Old 04-23-2008, 07:56 PM
  #22
C_Rules's Avatar
i put 396hp down with heads, cam, and boltons on a 3K stall. would have put down over 400 but had to leave the dyno shop. also that was on a load bearing dyno in OD with and a/f ratio of under 12! car kept shifting out of 3rd so we had to run it in OD. if my tranny was tuned properly at the time and i would have been able to run it in D i would have broke 400hp. and if it was a non load bearing dyno i would have put down like 410 even in OD.
C_Rules is offline
Old 04-23-2008, 10:18 PM
  #23
This is stricktly my drag car. I have my camaro for a daily driver. So 4200ish?
Old 04-24-2008, 01:47 AM
  #24
tireburnin's Avatar
If stricktly a drag car I would say yes to the 4200ish. Will it be an all motor setup or see any nitrous? If some light nitrous I wouldn't go over 4200. If on motor, talk to whom ever specs the heads/cam to figure out power band, but 4200-5000 would be good for an all out NA drag car.
Old 04-24-2008, 09:27 AM
  #25
blkchevyz's Avatar
i got 419 rwhp with a futural cam and cylinder head specialist heads, through a 9 inch.
that was at 5800 rpm too damn high end miss.
blkchevyz is offline
Old 04-24-2008, 04:00 PM
  #26
I will probably go with a 4200 just in case I want to put a small shot on it like 125-150.
Old 04-24-2008, 05:54 PM
  #27
My understanding is that for spray you hold the stall a little low because the big torque spike will push the stall higher.
Old 04-24-2008, 11:00 PM
  #28
I haven't really decided on nitrous but I do know I want to go with the AI 200cc heads and ported intake.
DirtyDaveW
12-01-2016 05:37 PM
10-31-2016 11:09 AM
Cam's maro
01-30-2015 09:21 PM
Killer94z
01-13-2015 12:06 PM
97 RedSS
06-10-2003 07:58 PM
Quick Reply: 400+hp on stock bottom end with h/c setup?
